21 - 38 of 38 Posts
Discussion Starter #22
Nice.
But you have to remember something....this is for my boys. They are 8, 6, and 2 (had birthdays since first post). They have to be able to see it and run it without using stools or chairs to stand on. So...that set my table height.
I can work with it...just gotta get a bit creative.
Discussion Starter #27
544221
Loop closed. Hinges installed on lift up section. Will need to figure out a counterweight system so little fingers aren’t caught in it. That’s for another day.
Discussion Starter #29
I’m no carpenter so benchwork is not my strong suit. I wanted that phase mostly over so I can get to the fun stuff...running trains, buildings, scenery.
Discussion Starter #31
544501
Tabletop painted a generic brown. I’ve got one loop completed with cork roadbed - it was cheap, what I’m familiar with, etc.
Question: how do you successfully cut Gargraves, or any other tubluar track?
I’m familiar with HO scale which is solid rail and Xuron track cutters work wonders there.
I've heard many recommend a Dremel tool and cutting disk. I have a basic 10" Ryobi miter saw, I replaced the wood blade with a 7" carbide metal blade and that did a great job cutting O-27 tubular track Just a slight clean up of the edges with a small file. I try that when I lay Gargraves for the first time on my next loop (after summer).. . IIRC, GRJ is planning on the mini saw from HD.
Discussion Starter #33
Thanks Mike. My wife bought me a cheap accessory set for the dremel from Harbor Freight which had heavy duty/reinforced cutting disks. Lasts much longer than the red ones did.
Discussion Starter #37
Every (2) pieces of flex track I’m adding in feeders. Bought them premade from Gargraves as I’d have too much help otherwise.
I have some 14guage wire I’ll run underneath as a bus...should be fine considering we’re only talking a 14’ x 14’ layout.
The one curve appears to have a kink in it...it doesn’t, optical illusion.
Looking good.
I didn’t see it mentioned, but it’s a good idea to put a micro switch on your hinge up section to cut power to the track 4 or so feet away when in the up position.
21 - 38 of 38 Posts
