Hi Group,
I thought I would throw this out to the group, before I PM flyer nut, PHD/AF. I recently started running a 21085 that has a derailing truck through my switches at low speed. This is most prevalent in reverse with the switches "straight." I can see a small arc at medium speed through each switch. If I go slow, in reverse that truck will derail and short. That truck appears to be "factory" and not an "add on." All of my other steam and diesel locomotives move through these switches perfectly in both directions. There could be an obvious problem to the trained eye, but I cannot see it. Maybe someone on the Forum has seen this issue.
Thank you.
Thank you.
