1 - 7 of 7 Posts
Hey all,
I managed to pick up a couple of used engines, and I was wondering what would cause the engines to stop and start on the track.
I set up a small oval of Power Loc track to run them, just to check them out.
One is a is, I believe, a Bachman Burlington Northern U boat, and the other is a Bachman (Hong Kong) Santa Fe F-7 (? not sure)..
Both were disassembled and cleaned, then reoiled and regreased.
I checked my track to make sure I had good connections between sections. good there...
I got them both to run, except, that while they are running, all of a sudden, the locomotive will hestitate, then start up again, and then run fine.
Not sure what the problem is..do they need more cleaning?
Any suggestions would be most appreciated:thumbsup:
Back in business:thumbsup::D
Cheers, Ian
Ian have you cleaned bothe the wheels and the rails of the tracks. I would use Alcohol on a old T Shirt for the wheels. Put some alcohol on the t shirt and run the wheels allowing the other wheels to touch.
For the Track No-Ox is the best product I've found. Walthers is a good source.
Or alcohol and a green scrub pad with a dry t shirt to follow up with.
Otherwise I wouldn't think they would hope on your track
And from the sounds of it the layout isn't too large.
I had a transformer that would cause that same problem.
Hooked up a different transformer and problem went away.
Might check that as well.
Jody
Ian did u check the lead wires from transformer? I had the same issue when i tested my current locomotives and one of the lead wires was cracked inside.
Chief,
No, these are the only two that do it. My third locomotive runs fine all the time.
I will check my transformer and try the alcohol idea with the wheels as well :thumbsup:
thanks guys,
Cheers, Ian
1 - 7 of 7 Posts
