1 - 6 of 6 Posts
I am about to build my train table (4 x 8) and I'm not sure of my next step.
Do I lay the track/ballast directly to the wooden surface or can I add a layer of styrofoam (not sure what thickness I would use) and lay the track on this.
The styrofoam or other material would be used so I can add some contour to the topography. Perhaps stream bed, culverts things of that nature. Major landscaping such as hills would be added separately. Any suggestions for a better material are welcome or telling me this si a bad idea are OK to.
Thanks
Steve
thank you reck :)
yea, i suggest laying a sheet of extruded foam insulation on top of your plywood. or actually instead of "suggest" i'll say that if i ever to start again i will still do it like this. with foam you can easily contour and create features in your terrain, stream, pond, dig a trench and make your train go under obsticle. i also used cork roadbed, yet one more sound insulation layer
Thanks tanklist
I think i'll stay with the plywood top to start. I'm thiking 2" of foam. So I'd have plywood, insulation foam and then start landscaping.
I'm beginning to learn how little I know about this hobby and I'm loving it.
1 - 6 of 6 Posts
