1 - 6 of 6 Posts
Hi all,
Anyone here a micro modeler or have a portable layout? I’m looking for a creative solution to place my transformer (rail power 1300) and block switches (I'm planning to use Altas 205 connectors) in a way that is convenient to access but at the same time keeps my layout portable and looking clean.
I have a 3’x6’ train table and want to use every inch of the top surface for scenery. The sides I plan to add a solid green fascia to create a nice finished look. I have seen similar layout setups online and in magazines without any visible wiring or transformers, and I’d like to do the same for my layout.
Maybe a separate tray table with an umbilical cable? I can't remember where I got it, but I bought a single table without having to buy a set of 4. They can't be all that expensive, and would be portable as well.
How good are your carpentry skills? With a little skill, you can make a drawer under the layout to hold your electronics. Get good quality drawer slides to mount it. Or you could just have a flip up panel on your fascia and a sliding tray behind it.
Lots of options, really.
I am making a tray under the table. I am using a 8" x 12" x 3/4" pine shelf and two 1/4" x 5" carriage bolts with nuts and washes. Bolts extend thru train layout board to tray. Simple.
In central europe it is a common practise to use the horizontal beams of the module bents to carry a portable board under the module, so you store all your electric equipment there and the boxes of your trains.
1 - 6 of 6 Posts
