1 - 11 of 11 Posts
I just acquired a Lionel engine and tender I would like some information concerning. It has a road number of 789 and the line is "Baimor & Ohio". I know this is fantasy line and assume the road number is bogus also. I will include several pictures and perhaps someone could ID this engine. Thanks for any help.
That is a 646/2046/2056 casting, look at the motor if aluminum side frame its the 646/2046 magnet motor if the frame is dark color its a 2056 non magnet made during the war only.
I think but not sure Lionel used same casting in some more modern engines as well.
I'm pretty sure it is the 2056 - The frame is very dark
Bingo. The cast piping behind the steam chest matches the 2056.
Thanks Mike....
Yes then if dark 2056, the casting is exactly the same as 646/2046 otherwise just the motor did not have magne-traction .
in 1952 due to material shortages thus re-numbered.
You have got a Lionel classic small, not-to-scale Hudson, but it's a great runner when maintained. I also exchanged the pill-type smoker for a liquid and mine is an awesome smoker. Your tender is a typical streamliner-type #2046w whistle tender, again another Lionel classic. Both are relatively easily maintained and because there never was a "Balmore and Ohio", although there was a Baltimore and Ohio, you could fearlessly strip the paint (why do that? It's a nice paint job from what I can see?) - and repaint it back to Lionel Lines or Pennsylvania tender with correct replacement decals including engine #, or paint it for a favorite railroad or even a different fantasy line.
1 - 11 of 11 Posts
