Status
Not open for further replies.
1 - 6 of 6 Posts
Ed gave me the idea with his suggestion. Common problems exist so I will add some common threads on a particular subject.
Any beginner should have a copy of the basic o/027 manual. You can save it from here.
To Transformers click here
To Track threads
To e unit for Marx and Lionel
The E unit, stubborn reverse device with a nasty history.
Solder, how to do it
Whistle, Thar she blows! Yokens theme.
Diesel whistle.
Prewar whistle discussion
6466x tender
More 6466x
whistle-horn button, make your own.
Smoke units. The stuff just gets in your eyes!
GRJ upgrade promotion.
2026 smoker
637 non smoker problem
6-18006 modern smoker .
More diodes more smoke
Wind your own
Yukon Jack rebuilds the Marx smoke unit to a 666
Trucks and Couplers
Truck Study prewar to modern and all mixed up.
Plastic Truck repair
How to install a knuckle with a spring and rivet.
022 switch
Servo guy link Bruce has done it all.
MTF discussion on the switch.
1122 switch
switch and bulb
Switch cleaning
test a switch
Modern 022 switch warning
These are just a few chosen t hreads. The search engine has a tag or w ord search feature. We encourage you to try it.
The purpose of this t hread is purely to be a reference. As usual, we recommend a separate t hread to encourage discussion.
Discussion Starter #2 (Edited)
Transformers
ZW roller and cord replacement
Transformer V starting voltage
Transformers connection to track chart- and KW check
How to phase two transformer together JW trains article.
Turn an AC power supply to DC
Any good service manual has this information. I know some of the Lionel train set manuals were extensive with product information on transformers and accessories.
LW Hum
hum is a key feature on buying tansformers, many have it. Most of the time it cannot be fixed if
too loud. One trick is to tighten any frame work against the plates to stop the vibration.
Wiring and How much Power? by Lionel
1033 whistle and diagram
Homemade Button Controller for Whistle Activation
LW Transformer
Postwar Engine Wheel/Part number
Quote from Teledoc and pdf files from Gunrunner John. It was easier to copy the files than the post. I am getting rusty.
I have the Postwar Engine/Wheel part numbers finally done, so that anyone looking for what wheel is used on a particular engine will know what part number to use. I compiled a list for Prewar O and 027 engines and this Postwar list, for anyone to use as a reference. Sorry that it is only in .JPG format, but someone like Rkenney usually sees these lists I post, and does a .PDF conversion. I use both XP and Windows 7, and by using the right mouse button, you can save it to your computer for your own collection.
I compiled these lists, so that people can search in one location, and find what you need.
1 - 6 of 6 Posts
Status
