With adequately spaced double track 6” on center rail spacing. How do you find a double tunnel portal to accommodate? I have a Class A on O72 curves don’t see a way to use a single portal. Do you have to scratch build?
Those fo look significantly wider, would you mind providing dimensions and you say it is K-line. I’ll check their website. Thanks for reply.The K-Line portals are wider than the MTH ones. I still had to raise mine up a little to accommodate the pantographs on my electrics.
