Now that I finally got a couple locomotives running on my layout I'm having a lot of derailments at a lot of my turnouts. Yes, the ARE Atlas. I first built my layout in the 70s and they were in my price range LOL So my question is, are there any economical turnouts out there that I could start replacing a few at a time? Right now I have #4s, #6s & #8s. (Atlas) #s . My only concern would be tearing up my road bed. I don't mind cutting track or filling in track. It would be the radius of the turnout to fit the road bed that would matter ! Any insight or suggestions would be appreciated !
zeetrains;
Atlas sells two different product lines of turnouts in HO-scale. Custom Line, and Snap Switch. Which do you have?
If the frogs are metal and have a little lug on the side then they are custom line, and they probably have two straight routes & no curved route. They would also have come without switch machines attached.
If your turnouts have black plastic frogs, one 18" radius curved route, & one 9" straight route, and came with a big black switch machine attached to one side, then they are snap switches.
The reason this matters is your statement about tearing up roadbed. Chances are, you will have to tear up a little roadbed, and some track, in order to make any replacement turnout fit. (other than another identical Atlas) That "one straight route & one curved route geometry is unique to the Atlas Snap Switch turnouts. The Atlas Custom Line turnouts with two straight routes would be a little bit easier in terms of fitting a better brand of turnout into roughly the same place, but no other brand will be an exact "drop in" fit.
Good quality turnouts are not cheap. The better brands are Peco, Micro Engineering, and Walthers. Any of these will cost about $20-$30 each. How many turnouts do you have? If its more than a very few, then replacing the Atlas turnouts you have with something better will be quite expensive.
The attached file "All about turnouts" has a lot of information on turnouts in general and my quality rating of seven common brands.
There are three lower cost options.
1) Fix the turnouts you now have.
The attached file "Improving Atlas turnouts " shows how to do this.
2) Make your own turnouts.
This is a lot cheaper, about $5 each for materials, BUT there's a catch. You will need to invest a lot of time. Its also only economical if you are replacing approximately ten, or more, turnouts. (Most layouts have at least ten.) There is another advantage to this option. You can make your turnouts any shape you want, including the exact same shape as an Atlas turnout so it actually can be a "drop in" fit. The attached file, "How I scratchbuild turnouts" explains this in depth, including cost of materials, tools needed, and the simple fact that anybody can do it. Its not hard.
3) Buy used turnouts on E-bay.
Risky, since you won't really know what you're getting.
Good Luck & Have Fun
Traction Fan 🙂
