Type S Transformer
4.6K views 22 replies 7 participants last post by  Reckers
#1 ·
My transformer has power coming into it, but no power coming out. There is no power on the outside connectors or any of the internal wiring leading to the windings. All loose wires have been soldered. None of the windings appear to have any breaks or any evidence of damage. Does anyone know what I can do in order to get my transformer properly running? Should I just buy another one?
Pepe
#3 ·
Does it have a circuit breaker or a fuse?:confused:
#6 ·
I never fooled around with an S type transformer.
Though I think I may have one in my box full of transformers, I will have to look.
#8 ·
Where do I connect the OHM meter?
Unfortunately, I can't answer your question without a schematic diagram. My answer was a generic type meant to help in a general manner. If you could provide make and model information we might be able to tell you exactly where to measure.
However, if there is no faulty fuse or breaker, then it's almost a sure bet the transformer is bad.
#10 ·
Hello everyone and thank you for all the information. I have learn quite a bit more about this transformer. But after testing different winding points, I have come to the conclusion that I indeed have a damaged transformer. Yesterday, I was at a Train Shop store and they told me that a compatible transformer to run this train set would cost me about $400.00. Does anyone know if there is a less expensive replacement?
thanks again,
Pepe
#11 ·
:eek:
No! No! No! Unless they wanted to sell you something with a solid gold casing!
You can ebay shop for a used 1033 that has a great reputation for around $30 or $40 ... around 90Watts, (your S is 80 Watts, I think).
http://www.tandem-associates.com/lionel/lionel_trains_1033_transformer.htm
For comparison, your S:
http://www.tandem-associates.com/lionel/lionel_trains_s_transformer.htm
You can ebay buy a new Lionel CW-80 (80 watts) for maybe around $45 or $50.
You can buy a much more powerful KW for under $100 if you shop around. "Hammered" here on the site has one in great condition for sale for $75, I think.
You can buy a super-duty ZW for mayber around $200
Cheers,
#14 ·
1947 Lionel locomotive disassembly
Hi guys,
Well, I bought and received a working Type S transformer for my 1947 Lionel train. Now I do have power going to the track. The only thing is that my locomotive does not move forward. I hear the contact being made and after giving it a slight push, it moves by itself about 4 to 5 inches and then stops. I believe since it has been sitting so long, it definitely needs some cleaning. But does anyone have a video clip (utube), step by step on how to disassemble this type of locomotive? Have been checking the internet, but have yet to find anything that will help me. I can probably fiddle around with it, but since I am this far along, I do not want to mess things up and have to buy another locomotive. Any advice or direction will be greatly appreciated.
thanks,
Isaias AKA Pepe
#15 ·
Pepe, perhaps you could identify the particular locomotive you have? I think it's likely that there's a thread here on the site that would guide you through it. We have a number of members who've generously taken the time to do step-by-step descriptions with photos, etc.
Best wishes with it,
#21 · (Edited)
Pepe, most model train manufacturers follow the practice of using the car id number as it's identity. Just as your car might say Chevrolet and Cavalier on the outside to identify the make and model, your locomotive says "Lionel" and "2025" to identify the model of locomotive you have. Any instructions for a Lionel 2025 should be applicable to your locomotive.
Here's a site that might prove useful: http://www.thortrains.net/manualx.htm
