I am using a UCS uncoupler track and was wondering , do you need to manually pull the train apart when pressing the button? If so that is lame. When you have alot of cars there would be too much force on the coupler to open and push the cars away.
Do you have the UCS or the #6019?I am using a UCS uncoupler track and was wondering , do you need to manually pull the train apart when pressing the button? If so that is lame. When you have alot of cars there would be too much force on the coupler to open and push the cars away.
Look at my round house and you see the 6019's? One on each side.It sounds as if john is describing the act of disconnecting while at a standstill---dropping a string of cars after backing into a siding, for example.
Mine uses the power of the track for the electro magnet so you cant run over it to disconnect(hence needs lots of voltsge). Separate power is the only way I know to do that and since the coil is connected to the tracks that would be hard to do. I found that the magnet has to be aligned with the coupler too for it to work.
Little by little the layout is changing. That's an older picture.Got it: great looking layout, by the way!
Since I don't run Lionel, I don't have the real answer about your couplings. However, it occurs to me that, by swapping the uncoupler-track with the straight track to it's 10 o'clock on the same line, you could do a moving uncouple and drop the rolling stock before reaching the turntable. That circumvents the need for the coupler to push the train backwards.
The O-27 UCS tracks have the wires from the controller soldered to the rails and coil. Turn the track section upside down and find the wire that goes to the center rail. Unsolder this wire from the center rail and wire it to a fixed voltage tap on your transformer. The instructions at http://www.thortrains.net/manualx.htm show you how to do it for an O-31 UCS, and the circuits are the same so you should be able to figure it out from the diagrams for the O-31 UCS.
Bruce Baker
HUH??Little by little the layout is changing. That's an older picture.
Ed,HUH??![]()
As Sherlock Holmes would say,Oh! I understand, now. Think of the center of the pic---the turntable---as the center of the clock. The decoupler is at the 10 o'clock position in relation to the turntable; the straight track I was describing was 10 o'clock of the decoupler: "to it's 10 o'clock on the same line". Elementary, my dear Watson!
