1 - 11 of 11 Posts
Maybe a silly question....BUT....can I use a Lionel transformer to run an American Flyer train? They're both AC 0-14 volts. Seems like it should work.
The reason is simple. I have a nice old AM train set with a transformer. But the knob is broken off the transformer. I plan to use this train set under the tree this Christmas. But so far I haven't found a replacement knob for the AM 1 1/2, 50 watt transformer. Ebay has complete transformers but I would like to fix mine and use it.
Any info would be greatly appreciated.
KT
Yes. You can use a Lionel transformer for
an AF train...or even an old Marx transformer.
They all have variable AC output for the track.
Most of my power consists of Lionel ZW's, RW's, and smaller. I also have AF transformers..To answer your question, yes you can use Lionel to power your AF.
I use a lionel transformer. I have a nice AF dual control (12B) transformer but I like
the lionel better. The AF transformer starts at 7 volts. The lionel starts at 2 1/2 volts.
So better slow speed operation with the lionel. I have a lionel ZW also, like flyernut's.
4 train control.
Thank you all for the info.
I suspected it would be a non-issue but always best to be sure.
Have a good one,
KT
No, I didn't know that. I saw that movie once many years ago but didn't catch the reference to Wampum. Though I have lived in the area, and knew Wampum quite well, I have only lived in Wampum for about three years.
It's a sleepy little village with a cement factory, the old limestone mines and not much else.
Good catch, I would have never remembered that.
4 train control.
I have an 18B American Flyer transformer but having issues with the two throttle controls. I have taken it apart numerous times to line up the parts that allow the variable speed. Which Lionel transformer could I use as a replacement? Thanks.
KT
I too use a ZW for the main control of my layout. Also have 2 12B AF transformers and an 1133 Lionel. All doing specific things and all are compatible since all are AC. The ZW allows for way better slow starts and running.
Kenny
1 - 11 of 11 Posts
