1 - 19 of 19 Posts
Hi again,Thanks for the help i have been getting.
This time i,m looking for info on a used engine i got off e-bay Its a 4-4-2
Chessie System Steam engine # 8403 Would like to know year of it and also where I might find the owner manual ( i looked on Lionel.com ) Unless I just missed it. A picture would be great.:)
Also has anyone made a retrofit switch to turn off the smoke?
Does it have a can motor. It will be under 8400 seies engine the color or road name won't help in the supps.
Your lucky day. I have a 8644, sounds like yours mechanically so go to supp31 page a 60 -3 i do not have the acrobatic page. this is the wire diagram
next supp 32 page a-63 for parts. Does the engine look like this?????
Station Master the Lionel Supplementals is the Sherwood Forest of information only a walk thru will you find. The sheriff of google has no power here.
I can't post a pic it's a download you can visit the site. i will look for my engine picture.
This is what I am referring to.....pic? Hmmm. Were you posting a pic for reference? Unless it is made of glass, I cannot see it. lol
Ok you shamed me into it. I had to take the picture. Upload to the puter Upload to Photobucket. I am waiting for photo now.Then upload here.
Ahhhhh This is a Sante Fe
Switch is top right picture for e unit but you can add one for the smoke.
Radio Shack has small ones.
I just noticed the engine number is 8632, but the tender says 8644 and the engine on the box says 8644. HMMMMM
You got to please the readers. Pictures are fun and add a new dimension. How many posts have you seen that you have no idea what the discussion is about. What do you think about my different engine numbers???
Supp 37 has a 4-4-2 with a worm drive can motor page 14,15 on acrobatic reader.. Nothing else between 25 and 37 supps other than what I mentioned.
Discussion Starter · #14 ·
I think you nailed it
The pic is correct Blue 8403. I looked in supps.1-9 Section 3-19 pages 128-130 that gave me parts and it did refer to 8403 and others so thanks for all your looking and help. marvfly
Discussion Starter · #15 ·
Think we have enough info now
Thanks to everybodys hard work looks like the year fall between 84-86
T-Man your pic look pretty close mechanically. just have to find a good spot to mount the smoke on/off switch since there are no moulded bosses to drill and tap. B&M found the exact pic of my train and probably the deal where i purchased on e-bay. So let me give a big thanks to all that helped. great group of guys!
All is well
That's good. The nice thing is that the modern engines use the same parts. I didn't think of the catalog. I knew the information was in the supp's.
Glad the mystery is cleared up.
You have some options with the switch. You could replace the switch with a 3 position switch. Wire it up for E unit, off, and smoke. Or just mount a switch next to the old one using a plastic tab held down by the old switch and glued to the new.
My son has one that looks just like it, from the same era. Its the Lionel 8641, C&O. It has a missing front "cow catcher" was bought that way off ebay :-(.
Kevin
1 - 19 of 19 Posts
