1 - 6 of 6 Posts
I'm seeing various features and not sure which matter for O scale modeling. Ignoring the bigger table construction jobs, when it comes to customizing/repairing rolling stock, buildings and scenery, what features matter? Is there a difference in glues?
This Surebonder CL-195F is at the top of my list for having the long reaching detail tip, mini overall size and battery-less cord free operation.
Other features I see but don't know about:
  1. Low temp units vs Hi temp units
  2. Interchangable tips
  3. Full size high wattage units
  4. Screw it, get one of each
I’ve never really looked into glue guns. Before I saw this thread, I thought they were all pretty much the same. I have a Stanley GR25 dual heat. It says 80 watts, so I guess low heat is 40 watts. It has a built-in folding stand that does not work well. I’ve burnt myself a few times when inadvertently using it on high. My biggest complaint about glue guns is they almost always leave tiny strings of glue when you remove them from the work.
I like some of the features on that Surebonder like the fine tip, cordless operation and a stand that looks like it will actually work. I think I will follow your option #4 and pick up a smaller gun. I’ll have to do some research and watch this thread to see what others suggest.
the option to have a choice of regular temperature and 'low' temperature is nice to have, but not a 'have to have' ..
i noticed on putting in some trees that the low temperature still melted the glue, but seemed to set firmly quite a bit quicker, needing less 'hands on' time ..
Hobo for Life
I never like the low temp setting on the glue gun. If i need more glue it never seams to heat up fast enough to use it. But its a 16 dollar investment. Get it use it and you will see if it fits your needs or not. I dont think you need 2 glue guns.
I have a little craft model with dual settings (15w and 25w). I use the 25w setting to heat up faster and then turn it down. I like that one linked because it's wireless and may buy it 'just because'.
Just for information, the higher watt models use bigger sticks. I haven't needed more than a dab of glue for my tasks yet.
I have a little gun and a big gun, both fairly cheap. They work fine for the stuff I do. I use the little one enough that I bought a second one in case it craps out (one did). All the wizz-bang features don't make a lot of sense to me, I just want it to melt the glue to dispense it and not drip all over my table!
1 - 6 of 6 Posts
