1 - 7 of 7 Posts
I am planning on using the digitrax zephyr as a starter set but need to know what track to use. Also if you have any suggestions as to a different controller for around the same price I would like to hear about it.
Digitrax Zephyr Xtra is a excellent starter set, just make sure it's the Xtra a DCS51 and not the DCS50! That is an older version and it does not have the controls to suport the new advanced functions of the new decoders! The main reason I like the digitrax system is that you can add onto it any way you would like, different throttles are available, boosters, controls, computer interface, are all possible and you never have to make a piece obsolete just add to it!
Track can be done several different ways.
Atlas, Peco, and others offer Sectional pieces of track and flex track (36" long sections).
Several manufactures offer EZ track that already has a plastic road bed attached. It's a little less work but it's generally cheaper track.
You want to get Nickle Silver Track not steel or brass.
Code of the track is the height of the rails code 100 you will be able to run anything made, code 83 looks a little more like "real" rails but you will run into problems with older engines, locos, and Rolling stock, the wheel flanges tend to be larger on them.
I completely agree with NIMT. I use Atlas Code 100 Track, it's wonderful! Code 83 does look more realistic, but it depends on your engines, rolling stock, etc...
Other than the color of the ties being the giveaway can anyone here really tell the difference between code 83 and code 100 track from 2 feet away? A difference of .017. On average a human hair is .004 as a reference.
It's not just the rails (you can see the difference though as it's a reduction in size of 17%) The ties are also smaller and more prototypically spaced. You can definitely see the difference in the ties.
That being said - I still went with Code100 because it's much less expensive.
I started with code 100 simply because I didn't really know any better and reading threads like this steered me in that direction. I later leaned that the club I joined, and the others around ours, all use code 100 for module construction as well.....so I didn't have to adapt my stuff to match.
1 - 7 of 7 Posts
