1 - 20 of 53 Posts
This time of year, I run trains in the morning before it gets too hot in the attic. Today it was my Reading GP9 (a Reading shell on a newer PS3 chassis). GRJ rewired this one after the shell swap so it started up with short hood forward. I also dusted off my trusty 2010 vintage Railking K4s and matching Madison cars. This loco has 1370 scale miles on it. From the old to the new, I got the LV RS-11 in April. Lastly a B&O F7 AB. GRJ also had his hands on this one to fix a balky switch and install a sound file that didn’t have obnoxious blower whine.
So, what are you running?
545044
545045
545046
545047
545048
My small N layout is in my basement, so I don't worry about the heat, I haven't done anything with the layout in over a year, no scenery or even running of any kind...just lost interest. Yesterday I went down and dug out one of my Kato D&RG PA-1s and started running it. First thing I had to do was clean the track! Then I discovered several places where the loco would derail, so I worked on the track. After a couple hours I have it running pretty well, but there are still a couple spots where the track needs a tweak or two. Felt good to be back at the throttle!
Supposed to get hot and steamy Bob, I feel for you.
Get one of those portable ac units?
I am in the basement but have been doing other things, trains are waiting for me.
I looked at a few Freidrich portable ACs, but portable ACs are not very efficient. And installing the hose(s) through the attic roof would be a giant PITA. Instead, I put a window unit in the staging area a few days ago. I ordered a Broan 380 CFM room to room fan unit and I’ll rig that up to blow air from the staging area to the attic. Probably won’t do the trick on super hot days, but it should be good when it’s less than 90 outside.
I think it would take a huge unit, amount of energy to keep an attic cool with the summer sun beating down on a roof. They do make insulation devices for attic ceilings. They use plain ol' pink insulation but, IIRC, these plastic panels allow proper moisture control / ventilation of the insulation..
Discussion Starter · #8 ·
It's insulated, but still gets stupid hot if the gable fan isn't on. It was 110 degrees F a few days ago. In the winter, a 1500W space heater will do the trick on all but the coldest days. Time will tell if the window AC and fan make it livable in summer.
I have not been able to run/work on any of my trains since May. Been busy working on several vehicles due for their state safety inspections for license renewal. 2019 taxes were worked on. Yard work & Garden soil prep & planting was performed. Busy summer for sure but I still found time to acquire some new to me prime movers. Now the heat is becoming intolerable. I must perform outside chores before noon before it gets to hot. Very nice looking rolling stock in them pics there Lehigh74.
LATER
I didn't know you had a window.
  • Like
Reactions: jackseamon56
Discussion Starter · #11 ·
House is a split level. The window AC is in the third floor staging area. There is a hole in the wall to connect the track in the staging area to the attic layout. I’ll suck air through that hole to cool the attic.
But doesn’t anyone have pics of trains they are running?
Where is the air return?
Sure...
Discussion Starter · #15 ·
I finally got around to completing battery replacements in my PS2 locos. Put some BCRs in 5V locos and SBRs in 3V locos. Ran the P5a modified and RK Decapod with the 5V boards. Also ran the B&O C-Liner.
545457
545458
545459
Discussion Starter · #17 ·
I haven’t run my Reading Passenger train for a while. I thought I would try it on the third loop that goes from level zero to 3”. I don’t remember running 18” passenger cars on that loop before so I ran slowly to check for clearances. Good news is the 18” cars cleared. Bad news is that the one powered F unit would not pull the non-powered BBA Fs and 6 passenger cars up the 2% incline. So I ran it on loop two.
546507
No pics but you can check my layout thread for video...
Right now it’s either my Lionel tinplate diesel w/matching freight cars OR if the boys want a steamie running then it’s my Ives 1661T w/matching 3 car passenger set.
Anything beyond that is whatever my boys want to run....Weaver Baldwin Sharks, Lionel GP9 (late 70’s version), Williams Berkshire, Williams FA.
Actually I am not running anything. Very frustrating!!. I've had to cut the power to the layout as I complete installaton of the final section of my wire-guided (Faller or AutomotionFX) Country Road for cars and trucks on my layout. It's getting rather involved moving wires and such to make room as I must . . .
Discussion Starter · #20 ·
Yep. That’s the downside of making improvements to the layout. I’ve had a few projects on the layout that caused me to stop running trains. After a week or so I was jonesing for train time. I’m planning to do some work on a few switches today, but that should only knock out one or two tracks and it shouldn’t take too long.
1 - 20 of 53 Posts
