1 - 15 of 15 Posts
Long time, no posts. but here is a structure I built recently:
White Rock FreightHouse by Monroe Models.
The kit
Unboxed
The first weathering using 'Weather it' by A-west (see this topic
The 'insides' / backsides got a coating of a gray primer
First I did the loading dock. I used PS boxcar red, SP lettering gray and Tie brown in a mix to try to get a creosotish 'look'. Then I used sand paper to wear it down.
I believe the steps need a little bit more sanding, but otherwise I'm happy with the result.
Then I begun assembling the structure, cheating to get the right corners...
The structure has been painted with SP lettering gray and the trimmings with E/L Gray (NYC-ish scheme...)
To roughen the painting a bit further, I've used a Dremel 'steel brush'
In a MRR magazine I read about a neat trick to lift panels: One uses a blade to carefully lift individual panels. I think it does the trick...
The doors have gotten an initial wash of grimmy black, than I brushed on Humbrols 27003 (a color one can polish!).
Then I put on the decals, and added som rust and a wash of Grimmy black again. Alas I didn't succeed with the decals. Wood is a different story than plastic...[B)]
The paddlocks are painted with Humbrol #12
Discussion Starter · #2 ·
The corrugated plate roof has now been glued in place. the copper sheet was cut in 1/2" * 1" pieces and painted a light gray color. Then glued in place slighly overlaping.
The rust is made up of different combinations of: PS roof brown, rust and zinc chromate.
(later I gave the roof a wash of good ol'e 'grimy black' [8D])
And with the doors in place:
Some lights (1,5 volts + brass lampshades from Miniatronics) as well:
I hid the wires in black straws glued to the inside of the building:
And a sign glued in place (after sanding it with a P600 paper...).
I scribed panels and used a needle. About 500 or so pounce/pricks later...I'll have to get me a pounce wheel [:)]
Great work, nicely done. The detail is amazing that you have brought to life.
I am definitely interested in a kit like this, even though I don't model North American I'm sure it could be used just about anywhere. I took a look at Monroe's site and there is some interesting stuff there.
Very nice job!!! :thumbsup:
I have never even tried to build a building yet since I do not have a layout, but I was wondering, how long does it take for you to make a set look that real?
I am not really a patient person, and I do not know if I would ever be able to sit down and create a masterpiece like this...
Thanks guys :)
I think this kit could be made to fit just about anywhere!
It took me about 8-10 hours to make this kit. A lot of the time is waiting for things to dry. This was my 2nd attempt at building wood structures, they are not that hard :p
Freight House
Thanks guys :)
Fine piece of craftsmanship. I'd like to try it eventually and
I'm saving your post as a guide--but you have really raised
the bar!:thumbsup: A challenge and an inspiration.
eagle37
More on Freight House
Thanks guys :)
Those struts under the platform--do they have to be cut out
individually or are they in a strip or pre-cut?
eagle37
1 - 15 of 15 Posts
