Edited for clarity.
My HO layout runs on DC. I'd like to wire a crossing signal such as the one in this link without going completely digital, if possible.
That is, no detector circuit boards. Possible?
https://www.trainboard.com/highball/index.php?media/new-crossing-signals.123324/full&d=1436201455
So aside from a required opto sensor between the ties (an edit from "digital detector", which is what I originally wrote), is it possible to wire the crossing signal so that the lights flash and can be turned on and off by use of a center-off DPDT toggle switch or some other simple electrical component connected to an AC/DC power pack (the one that controls the Tortoises on my layout) and an opto sensor? Or, is such a elemental setup incompatible with an opto sensor?
In brief: An opto sensor between the rails + a center-off DPDT toggle switch on the fascia + a power pack (using the AC or DC terminal?) + wiring to all three. Not a circuit board in sight.
Will that setup work? Such a wiring scheme compatible with an opto sensor?
Thanks!
Thanks!
