1 - 4 of 4 Posts
Anyone have any pics of how you have wired your layout lights. What type if method for connecting your lights together, i.e. soldered, wire nuts with a lead going to a power supply or to a terminal block etc.? Any help would be appreciated. I have multiple lights inside a structure of store fronts some other structures. Looking for ways to handle all the leads etc.
Thanks
If it were me (And I will be doing it next year, probably), I wold be running a pair of wires, own the center or terminal block to terminal block (near the buildings) running off a DC accessory terminal. Each LED will likely need a resistor (330 or 470, and confirm this with a google search), and be run to the nearest terminal block.
I use distribution block powered by a wall wart. Makes it easy to change stuff around if needed
I used a large walwart that was the power supply for a VHS tape rewinder as
as a 12v DC source. I ran a 'lighting bus' under the table and used wire nuts
to connect the drops from buildings and street lights to it.
If I had it to do again, I would have used the 'suitcase' connectors. Much
better system than all the cutting and splicing needed for the wire nuts.
1 - 4 of 4 Posts
