1 - 20 of 23 Posts
Been using a refurbished ZW 275 for a couple years. Just a few hours a week at most. While just running the trains, I heard a loud Pop sound (like an arc) from the ZW and then smoke came out of the right side. Everything still runs except the whistle doesn't sound on POST D. I switched the track to POST A and the whistle sounds but also reverses direction if the whistle control is pressed all the way. I have to admit I never tried the whistle on POST A so that may be unrelated.
I opened it up but there's no obvious damage I can see. Any suggested repair tutorials or trusted repair centers?
Pop, smoke, no whistle points to the rectifier that provides the DC signal for the whistle.
Did it fail when activating the whistle?
Thanks Pingman and John,
I followed the test procedure at tranz4mr. The D side reads 21v at max throttle and 26v at the whistle position. The A side goes up to 26 then drops to 3v or something once the lever moves past a certain point. In terms of placing an order for one versus two rectifiers, is it the rectifier that's bad on A or something mechanical on the A switch? TIA
Try setting the voltmeter to DC. Then activate the whistle. If it reads zero (in conjunction with your earlier measurements) the rectifier has shorted closed. It is letting the 5 V AC whistle winding through without rectification to DC thus adding 5 V AC to the max throttle 21 V AC.
Me,. personally, I'd put in a modern 10 amp 100 V diode. But, I don't own a ZW and I don't know how important it is to keep it "original".
Discussion Starter #10
I'm confused. I see that the power cord and thermal circuit breaker were replaced in the rebuild but I don't see any rectifier discs nor the 1N1190AR Stud Diode. What the heck?
Discussion Starter #11 (Edited)
EPILOG: Mystery solved. I heard a rattle when I tilted the unit to move it. The reason I saw no rectifier was because it had blown up. That was the pop and the remaining bits were black and camoflauged inside the case. Anyway, I figured it out by comparing the remaining fragments from the D post to the A post. That's when I saw the can shaped rectifier on that side that was missing. As for the A post whistle stopping when pushed too far, it seems the rebuilder inserted the wire tension spring wrong which allowed the switch to travel past its contacts. I think the case will cure that problem. TBD
IIRC, you posted a 100 A diode from eBay. I would use a 10 A 100 V diode like the one remaining in your ZW. 10 A should be plenty for a whistle and several locos on the same post. And I'd rather replace a diode than overheat the windings or fry contact points.
And that fat can is one of the connections (it can touch / short) where as the black body of the diode in your pic is insulated. You can find that same case type at Digikey in 100 V 10A (and 12 A / 15 A for that mater) for a buck or two. For small parts like that, Digikey's shipping is very reasonable at ~$3.75. Buy a couple for spares (and impress you friends when their ZW needs one :laugh:)
If you need help finding the diode, let me know.
Discussion Starter #14
Did I say Rectifier? [blush]. Yes. 10A10 Diode. :eek:
The explosion was so violent it bent the top lead back and shorted on the frame (I bent it back in the photo). Thanks for the pointer to digikey but I had already ordered 2 replacement Diodes from mouser.com and since I was paying $8 shipping, threw in a 40amp 600v Stud Rectifier using the part number recommended by Tranz4mr. I got options. :)
Discussion Starter #17
It happened again during a whistle blow only 10 months later. Any idea why these diodes keep blowing up?
It sounds like you blew the rectifier disk on the d handle. This is usually because the whistle switch is worn and gets stuck on, overheating the disk. On the A side the contacts in the whistle switch either need adjusting or need to be replaced.
Kent Schwarz
Website www.tranz4mr.com
Email Tranz4mr at Tranz4mr dot com
Read Only
Question about rectifier disk
Gunrunnerjohn, you mentioned that the original rectifier disc is a selenium type. I was always under the impression that the disc is a copper oxide type, not selenium. I have never seen them referred to as selenium rectifiers. I am very familiar with the old selenium stacks that were used in old radios, TVs and jukeboxes.
1 - 20 of 23 Posts
