Bindng Post T-159 part number
For Parts, you can Google a Dr Tinker, out of Mass. Parts people normally attend the larger Train shows. if you want to go local. Since the ZW is the biggest and best you probably don't want to go with a bolt and two nuts.If you want to service your transformer order some carbon rollers and pins, you need four, two for each handle.The pins are ZW-102 and rollers are V-45.This has been recommended to me from an experienced train repair man. I did the nut and bolt on a KW Transformer.
Good Luck and Happy Rails!
