Bad Short
1.4K views 5 replies 6 participants last post by  T-Man
#1 ·
large two train layout. Bad short, unable to find, dismantling sections . Any easy way to finf it. Losing patiences:(:(
#2 ·
Following your post in another thread http://www.modeltrainforum.com/showthread.php?t=10718 I see you were adding additional lockons. Did the problem arise during that? If so, make sure that all connections are the same. I.E. 1 to 1 and 2 to 2. When a problem arises after a change, undo the last change and re-test.
#3 ·
After working past midnight, I'd say, walk away.
Whenever I'm stuck, I find I make the same mistake over and over, or at least variations of it.
#4 ·
dismantling sections .(
That's the right approach ... simplify.
Could be a bad insulating strip on a crosstie at the center rail. Could be something in way of a turnout. Could be some small debris on the track.
Have you checked for a short with a multimeter with no loco on the track? (Should be no conductivity between inner rail and the pair of outer rails).
#5 ·
Disconnect everything and make sure there is no short. Next, reconnect in small sections. Eventually you will connect a piece of track or a lockon and there will be a short telling you whats shorted.
#6 ·
A short was cause by something you did. Retrace you steps.
I always look for the screw driver on the track first and the car that I bumped on a powered siding. These are 90 % of my shorts.
If it is a bad track section it may be hot to the touch.
