First point - you handle each one independently, the way you always handle a reversing loop.
Are you using DCC? (You said "being new to doc" which I assume is a keyboard auto-correct)
Reverse loops are actually pretty easy - you just need to reverse the phase/polarity on the loop. Three options:
1- manual toggle switch, but this requires the switch and the action to flip it which you don't want
2- using relays or auxiliary contacts on the tortoise machine (built in), but this requires some careful thinking and making sure that it switches the right way and is probably not going to be possible to work right for the loops you have drawn. This can work well for the tail of a stub wye, or a loop that only has a single switch leading into it, but your loops connect at two ends to different switches. Not a major problem, but kinda make option 2 "difficult"
3- automatic reversing unit like a Digitrax AR-1, requires a more expensive electronic piece, but is dead easy to wire in, and is totally automatic. You don't need to think about it when running trains after it's wired in.
Gap both rails of the loop, at both ends of the loop, just past the switches.
