How high is your bench work?
5.5K views 31 replies 17 participants last post by  Aqualungs
#1 ·
Just starting my first in depth scenic ridge RR. I like to stand to work on things and It pains me to bend over and do dishes. What’s a good height for the base of an N RR?
#2 ·
My HO layout is at 44 inches and this works good for me at 5'10" although
sometimes I wish I had gone 2 inches higher but don't really know how this would work.
Mostly it depends on what you find comfortable, it's different for everybody.
Stack some stuff on the kitchen counter and try different heights.
Magic
#6 ·
My track height is 4’1 3/8” off the floor and that works well for me. Unfortunately there are many places I can’t easily get to on my layout from the height I chose. I have long sweeping curves so that makes a problem getting everything scenic in the far corners of my layout. There is one place where it’s 6’ from the edge of my layout to the corner of the room. I think that may end up as a corn field at some point
#7 ·
Well, you're not alone in that. Most of us have those problems. A pad to stand on works wonders, too.
My benchwork is 42" high, so with the foam layout base, track level 0 is 45" off the floor. Some areas of the layout are 3-4" higher than that.
#15 ·
I do wish I could get a top-side creeper into the room. If I could I would be able to fill my access holes and complete scenery in those spots.
#16 · (Edited)
Mine folds up. You can carry it sideways like a ladder (easier with 2 people). I bought it at Harbor Freight about 8 years ago.
I see a Traxion-3 for sale (not at Harbor Freight) that's essentially the same thing.
#24 ·
Getting back to this subject, I believe the perfect height would be one that allows either laying on a creeper and being able to reach up without straining, to do wiring or high enough to stand under and reach up comfortably. At the moment, all of my empty boxes are stored under my layout. Preferably, they would be stored somewhere else, but that somewhere is nonexistent.....LOL.....At least thats the work from SWMBO.
#25 · (Edited)
Here's my take on it:
Model trains look more realistic when viewed from the side than down on them..Why ?
Because in real life we see 1:1-scale trains from the side 95% of the time as opposed to from above or below them...So it helps make the model more believable/realistic, as if we're seeing the real tingalingaroooonio, but a tad further away, say..
Thus benchwork/sub-roadbed up at chest or even chin height [while standing] is my cup of tea.
There exist a group of modelers in this school. I juzzzz belong to diz school, too..
But you dozzzn't got to !! It's truly ~ Do what you like ~
There's no MRRing rule, nor is it scale-relevant. Same 'school' for all scales.
With it up high, tho, it's easier to get under the bench to do various things, especially if it's a 'duck-under' design..And you can keep a small type, arm-less office chair under it and push yourself around (backwards) with your feet and do 360-spins back in the aisle-way ! ..WEEeeeeeeeeeeee !
#26 ·
Model trains look more realistic when viewed nearly from the side than down on them..Why ?
Exactly the reason mine is so high. I have some bar stools around for when we want to sit and the rest is history...
#27 ·
I either stand or sit in an adjustable drafting chair while operating. There is plenty of room under the layout to work on wiring. Sometimes I use a low stool for lengthier jobs, or just kneel if I need to meter something or just check a connection.
#32 ·
About 36", maybe could have went 40. I'm 5 10 and at least I can sit down there. Lumbar discs were removed and fused so I can't stay down there long. Bavk had been screaming at me for days, dying to get back under there and finish. A creeper might be more comfortable for me lol!
Sent from my SM-N975U using Tapatalk
