MTH 10-1037 activation device
1 reading
2.1K views 6 replies 3 participants last post by  gunrunnerjohn
#1 ·
so I got a light that came with this device, got it wired up and if I hold the device in my hand and press and release it does the color changes from green to red correctly. Now if I put it under the track no matter how much I try adjusting the knob I can't get it to do the change as the train goes by. It is on a straight piece of track (O27). Any ideas? Also is it at all possible the road bed is causing any issues?
#2 ·
You need to make sure that the track near the activator is free to move a bit. If it's firmly screwed down, it'll never flex enough to trigger the switch. This is why I favor the IR sensors beside the track, that is not an issue with those. This also goes right under the track, not under the roadbed.
#5 ·
The picture showed it with the "ties" sitting on the activator. I watched it at track level, trying many adjustments of the knob and still no luck. I moved it so the rails sit on it. I watched it at track level and train wasn't pushing it down enough to activate. Played with the knob some more and it is now working!!
