21 - 40 of 66 Posts
Lot of similarities here, except your layouts are better ! I've been reclaiming a corner of my workshed, by insulating and lining, then installing reclaimed cypress pine flooboards. Long way to go yet (I need a front wall, a door, and a ceiling) but here are some shots of progress to date (if I can get them to upload - bear with me).
Nope, it doesn't like my images. In fact it doesn't even like my posts. Topics I started weeks ago have still not appeared. I give in. I'll join another forum.
You have no photo links in your post, unless you previously deleted them.
Are you uploading linked photos from a server or uploading as an attachment from your hard drive?
You cannot upload directly from your hard drive.
I'm afraid I used the 'Manage attachments' button, which seems to invite me to attach any of a fairly wide range of image files ... viz
Attach Files
Valid file extensions: any avi doc gif jpe jpeg jpg mp3 pdf png psd txt zip
Can the system handle a Dropbox link, e.g. this one ?
https://www.dropbox.com/sh/rya8vkj4adh9e6t/AADz43KcFp_wQsuN4yFpxTy8a?dl=0
here, my copy and paste
After you get 5 posts done, look up top in the posting box.
You click on the paper clip next to the
smiley face above.
It will give you a new screen
where you click on choose file.
That will take you to
your computer's picture files.
Select one and click
on open.
Then upload.
After you see that the upload worked, X out of that box.
Then click on the paper clip to insert the picture.
If your picture won't upload it might be too big.
Attach Files
No, not as an attachment, but as a link to a photo server if you right click, select copy image location and use image tags like this:
But the link address is a mile long. Just use Imgur. And resize your photos to something more reasonable like 800x600.
We don't really need or want a photo that is a bazillion pixels in size.
This is my new Deutsche Bahn five track staging yard.
The outside track on the right will have an additional right hand turnout, a short length of straight track, and then split into a #5 wye with two additional tracks that lead into a Deutsche Bahn electric engine servicing facility. It will be placed at the far end where the yard ladder angles to the left.
One of the service tracks will be a dedicated programming track. I ordered the wye tonight, so by next Friday I hope to have all of the trackage completed. The two service tracks will not be attached to the sub-roadbed until I purchase and build the service facility because I do not yet know what the track spacing is going to be.
Now that is really weird, because ...
. If I go to _this_ URL (i.e. _this_ page of the forum) _without_ logging in as me, so I could be anybody looking at the forum, and I click on my dropbox link, it take me straight to my photos, all nicely laid out as thumbnails, and readily clickable.
. And you can see from the above quote that what I see with _your_ image tag example is even more zillion characters.
The upshot is that I still don't know what's going on with images here. Sorry. My bad.
Ah, that's exactly what I tried to do in the first place, but it probably fell over because I was trying to upload all of them simultaneously. And they were big file sizes
Then one of the forum posts above said that you can't actually upload from your hard drive. But that's exactly what this is ?
So ... here we go then ... original file sizes are a bit large'ish but way smaller than the Mb limit specified in the Management Attachments box. Regardless, I have resized them to be quite small.
As I said earlier, lots more to do yet, e.g. a roof, a front wall, a door, and heaps still to do on the layout.
You are uploading photos from your hard drive; to the site's server.
I should have said you cannot post photos directly from your hard drive.
fyi - when I was uploading photos in my new member post..
the box for attachments shows 10 lines and I click browse, select photo for each one.. added 10 but it fails...
I then did 6 and it failed.
did 1 and it worked..
so while it will show 10 lines to upload... I could only get 5 to work at a time...
I see you have 6 so maybe that was the issue?
wow this is so cool! LOVE IT!!!!!
when I do my HO, I will have to do something like this as I will have many trains out and would love this setup.... also wanted to incorporate my turntable...
sill question....
I see the turntable at the end and no tracks behind it... why? I have a turntable and want to incorporate it but never thought of it at the end... :thumbsup:
I think the obvious answer is 'because that's not how he built it on his shelf layout'.
I guess in theory one would want various engine sheds around the turntable, but he didn't have room.
Discussion starter · #33 ·
Hi scottmac99, That is a really nice shelf layout you built. It looks like you used real dirt on the base, it looks good. How long is the shelf layout?
Ed
Regarding the turntable, there is of course precedence for such an arrangement when you simply need to turn your loco around. I've seen other views that go along with this photo, and I believe the story was that the loco simply needed turned around after dropping cars off on the spur, so there is only the single line heading into the turntable.
I know the view is weird here, it looks like the track goes right up to the side of the turntable. It actually does not, it just looks that way because of the grade of the track since the turntable was placed right at ground level rather than being dug in.
Ed
1.9 meters. The baseboard is an Ikea 'Lack' shelf, that comes with a metal framework to enable effectively invisible mounting to the wall. The shelf itself is ultra-lightweight.
It was (and is) a bit of an experiment, but I couldn't import the baseboard(s) I wanted (from the UK) because of the Oz Govt's restrictions on importation of wood products that are not certified as having been treated to get rig of bugs.
So I sloooooowly built up the back and sides, as shown the pics attached. The overall structure is still pretty light, I can easily lift into position on the wall.
There is a shorter version of the Lack shelf, so in theory I could extend the layout at one or both ends.
The plan is, of course, closely based on John Armstrong's switching puzzle, with the addition of the turntable. The turntable was never meant to send locos anywhere, it was a means of turning them (should I want to to) but more importantly to act as a sort of sector plate. By having the turntable instead of extra track, I've probably saved a half meter or so in the length of the baseboard.
The only drawback with the turntable (as I have posted elsewhere) is that one of the rails lost power. I eventually worked out how to get the top surface off, lifted it up and exposed the two little spring-loaded lugs that pick up the power and transmit it to the track (and also reverse the polarity as needed). The only problem with that was that one of the teensy-tiny little springs went 'ping' and bounced off to I know not where. I could barely see it when I knew where it was, let alone where it might have gone to. Somewhere on the floor probably. I dragged a magnet around trying to locate it but to no avail. So power is now (for the time-being) delivered to the turntable via a couple of ugly screwed connections right next to the sidescene. That of course means I can't use the turntable as a turntable proper. But I've decided (out of necessity) that using it as sector plate is fine (and also adds just a little more challenge to the switching tasks).
[Replacement lugs cost only $USD2.30 approx, but $USD20.00 postage from the USA to down here, which amounts to about half what I paid for the turntable in the first place. So I'm not buying any.]
The trackwork is Peco HO/OO even though the layout is On30 (with Bachmann locos and cars). My technique is to remove every third (say) sleeper/tie, then rearrange what's left so that the track looks a bit rustic.
Yes, the ballast is real gravel, collected from the roadside, and sieved to be super-fine, then applied in the usual way and fixed with a white glue/washing detergent solution dripped on.
The Peco turnouts allow for super-reliable electrical continuity, if you can be bothered setting them up with the appropriate switches. I've just left them as is and they seem to work OK. I had contemplated some sort of wire-in-tube control from the front of the layout, but decided that the big-finger-from-the-sky would be good enough. And it is.
It's a tiny little layout, but one that I find is fun to use. Lots more to do, e.g. build up some of the Clever Models card kits as building flats/low relief to go on the backscene.
I'm currently using just two locos, the Bachmann On30 Forney, and and Ixion Models On30 'Coffee Pot' (based on a real-life and still operating Sth Australian prototype). Both are very good runners. The Coffee Pot doesn't have couplings as such, so I use it more as a shunting device. It also functions as part of the puzzle, in that when it's in the way, I have to move it to somewhere else on the layout. Unfortunately it's just a tad too long for the turntable, but that's not a biggie. [I also have a couple of the Bachmann gas 0-4-0 engines, but they are pretty unreliable electrically because of the very short wheelbase - plus one of them seems to have stripped one of its drive pinions.]
There's lots of examples down here, too, of turntables installed solely for the purpose of turning locos, with no shed or stall in sight, eg. Daylesford, near where I live ...
https://railgallery.wongm.com/daylesford-spa-country-railway/F137_6604.jpg.html
And Victor Harbour, Sth Australia ...
Discussion starter · #39 ·
That is a nice setup. Your shelf layout is a little bit longer than mine.
Ed
With a serious tongue in cheek, this is my Lionel HO Texas Special repair shelf. Some of the engines run, just not under a load. I have a motor into Just Trains as they have a Lionel Remagnetizer Motor Service. Although they have had one motor since before Thanksgiving. If that works, the rest will go in.
But here is my repair yard/shelf. Long story but have a serious sentiment to the Lionel Texas Special and have been just having a blast collecting them. I have at least 6 more running A Units and 4 B units stored underneath the shelf.
21 - 40 of 66 Posts
