Your smoke unit is the newer style, that is there's no bottom plate. The older style with a bottom plate is much easier to repair than the newer style, in my opinion, but I haven't repaired a newer style. All my 283's have always been great smokers. I don't know what the insides look like, but I'll have a go. You thread the ends of the wick into the 2 small holes in the smoke unit, and just keep pushing more wick into the lower chamber. You must, however, wrap the nichrome wire around the wick before you do this. Wrap it around 12 times, making sure the wire doesn't touch itself or the side of the chamber. When you get everything into the chamber, you run the ends of the wire through the lugs on the top plate, and wrap them around the lug, about twice. Solder will not adhere to the nichrome wire, so you must embed the wire in solder..Screw the top plate back on and add some smoke fluid. Attach 2 leads coming from the transformer,track power, to the lugs. Give it about 1/4 throttle, and gently blow air into the piston area of the smoke chamber. You should see smoke coming out of the hole of the top plate.
