241 - 260 of 283 Posts
Discussion starter · #241 ·
Kato N Scale Library ?
I am using SCARM to document my layout and I cannot find a particular Kato item. It is a Kato N 20866-1 Unitrack Double Crossover. Does anyone know why it is not included in the library? Also is there a work around? Maybe using two turnouts?
Discussion starter · #243 ·
Kato #20-866-1 is expansion set that contains several tracks, including the double crossover #20-210. The libraries in SCARM contains only single track pieces, and the double crossover is already included.
Mixy
Thanks for the reply. I, however, cannot find the double crossover in my library. I have checked and I have an up to date copy of SCARM. Perhaps you could tell me where it is located that is between what objects. Thanks
Discussion starter · #245 ·
Thanks Maxi! But I still cannot find it. Attached is a screen shot of the bottom of the Kato N Library. Do I need to uninstall and reload?
That looks to be the Atlas N-80 track listing you have posted. You need to scroll down to and select Kato, then select the Kato N-UT track library. You will find the WX310 above the (Kato) turntable just like Mixy said.
Discussion starter · #251 ·
The new SCARM v. 0.9.35 is ready and published! It comes with many new and updated track libraries, many bugfixes and more powerful Model Trains Simulator extension. See more about the new version here:
SCARM Track Planning Software 0.9.35 Released
Together with the new release, a new part of the website is also launched - it is a database with Virtual Rolling Stock for use in the MTS PE extension.
Hope you will like all new stuff about SCARM ;)
Mixy
Discussion starter · #252 ·
IMPORTANT!
A bug was reported and confirmed in the last version of SCARM that may prevent starting of the program on some computers. The patched version of the program was released today. Please upgrade to SCARM 0.9.36, which can be downloaded from www.scarm.info to fix the issue.
See more about this bug-fix update in the following blog post: SCARM v. 0.9.36 Released.
I am sorry if the bugs caused any problems and inconvenience in your work with SCARM. If you see another problems, please report them here or in SCARM Blog and I will try to fix them ASAP.
Mixy
Discussion starter · #255 ·
Thank you, Warren :)
@ClarkW: Well, that depends on the selected library and they are more than 160 in SCARM. It could be the length for straights, radius and angle for curves, diverting ratio for turnouts, just part numbers or something else.
Mixy
Discussion starter · #259 ·
If you want to play with SCARM track planning software on a mobile device, this is the only way for now:
Using SCARM on iPad and Android Tablets
However, for more complex plans and faster work, a real mouse and keyboard are actually mandatory.
Mixy
